After 20 years I think it's time to change the low pressure hoses again for the power steering lines because some black specks are showing up in the reservoir screen plus the pump has started to grown a bit with no steering wheel input. The online Toyota diagrams are less than helpful. They show a part number 44348A that requires more digging to determine which part number is for the reservoir on the fender or the reservoir next to the cam position sensor. The part number for the Turbo car with the reservoir next to the cam position sensor turns out to be 44348-14120. The other longer feed hose for reservoirs that are on the fender is 44348-14100. Turns out I cannot find the Turbo car hose hose anywhere now so I'm to the point were I'm going to take my ancient spare part to Napa and try and match up the shape in a longer hose and cut it out. The hose inside diameter needs to be 5/8 or 16 mm which is the diameter of the metal pipes. The overall length of the original part is about 6 inches with the 60° bend being slightly off center toward the top. Has anyone found a donor hose out there to cut a replacement out of? The low pressure connecting lines are much easier since you can use 3/8 oil hose. I already have some Continental Derale oil hose that works as engine or transmission (power steering) oil hose. I have replaced the engine oil cooler hoses in the past with this hose. It's best to use a ideal type hose clamp for the hose that comes out of the oil filter housing. The Toyota spring clamp can't keep enough tension when that hose starts to get hard and begins to leak.
Ideal 52F16 for 3/8 inside diameter hose
