61 - 80 of 103 Posts
Kappa Check 1 2
Discussion Starter #61
After base coat I applied the sticker
248943
And then some clear coat!
248944
Not 100%, but much better than before and I’m very happy with them, they’ll hold me over until I get them powder coated.
248945
248946
248947
ABS delete kit from PHR
248948
Driftmotion hydraulic clutch release bearing, decided to use this after dicking around with the OS Giken alteration kit for way too long.
248949
Some progress pics from the recirc job!
248950
248951
And then update pic of it completed! He knocked it out insanely fast ?
248952
  • Like
Reactions: ajgibson528
WOW!!!!! GREAT WORK, Rich! Look at that engine bay...I feel like im right there in the garage with you. What awesome photos to share.
Quick Question. Is taping your valve covers for the AN fitting or Welding on the AN fittings a better idea? Are the threaded fittings a cleaner look?
Adam
Kappa Check 1 2
Discussion Starter #63
Adam
Thanks so much Adam! It means a lot!
As for the AN fittings, I only did that to have a more flush look, I’m not sure if either is better than the other honestly, both get the job done!
-Rich
Kappa Check 1 2
Discussion Starter #64
I really admired the work on the recirculated wastegates, I almost didn’t want to get them ceramic coated! Here’s a few more pics once it was in my hands.
248953
Along with the compressor cover elbow welded on
248956
I also had him pinch and weld this water pipe I didn’t need
248955
And also this water neck, which needs cleaning/paint
248957
Since I love any and everything HKS related, I decided to buy this spark cover since it was a cheap pickup from friendly supra owner Jason (TheProPilot on YouTube and that might be his handle on here as well, thanks buddy). I wasn’t sure if I’d use it, figured it would be cool garage deco if anything. Ah hell, let’s get it powder coated and decide from there!
248959
With powder coat in mind, these are the colors I decided on for the parts, very retro hks like, but a bit of a twist for my taste (as well as my wife’s, she picked a little bit of teal to throw in the mix haha)
248960
Meanwhile I dropped off the hot parts for ceramic coating, after a few months of shop changing owners and parts getting coated in a finish that I didn’t order....the new owners were a pleasure to deal with and nailed the finish I was after! Satin black ceramic
They look grayish in this pic from the sheen in the sun, but they are indeed black (more pics below)
248961
248962
Test fit!
248963
248964
Kappa Check 1 2
Discussion Starter #65
Before I forget, I’d like to point out the very falace shaped billet oil drain ?
248965
248966
248968
Wastegate Springs installed: Black/Blue/Yellow = 1.2 bar/17.4 psi, I hope I don’t regret this lol.
248969
Also before I forget, TRD engine mounts were had and installed. You can spot them in some of the previous pics
248975
I sent off the compressor cover to good friend Tuan (Biologist...who doesn’t know him!) for his guy to polish, I wanted to get this done before it got powdercoated to acheive as smooth a finish as possible when coated. Thanks again buddy!
248976
Back to the fuel filters, I did pretty much what Boost Wang did to a T other than build the bracket the way I saw fit.
248983
248984
248985
That’ll do for me
248986
Kappa Check 1 2
Discussion Starter #66
Test fitting the harness
248987
248988
Decided to clean/paint the getrag, if everything else is getting love so should the v160!
Before:
248990
248991
After:
248992
248993
248994
Some SEM Trim Black for the reverse lockout collar
248995
248996
And used the SEM paint to breathe life into the windshield cowl
248997
Kappa Check 1 2
Discussion Starter #67 (Edited)
Installed the ID2000’s after I got them back from flow testing and having 2 of them replaced!
248998
248999
And installed the PHR T-stat rotator to clear the turbo.
249000
I think it’s time to get this motor/trans back in, at this point in time it’s been 2 years 1 month since I first pulled the stock motor out.
249001
Clutch has to go on first as well as the hydraulic release setup.
Os Giken Quad
249002
249003
249004
249005
249006
249007
Kappa Check 1 2
Discussion Starter #68
All installed and torqued
249008
249009
249010
Time to fill with the ole unicorn blood
249011
249012
249014
249015
249016
249017
249018
Kappa Check 1 2
Discussion Starter #69
And finally, it all goes in for the last time! Have to personally thank my wife for saving my motor as well, right before we were about to put it in, I go to open the garage and the edge of the cherry picker got caught by the lip on the garage door and started raising the entire engine/trans/hoist and she screamed for me to stop the door so my heart drops as I’m running to hit the switch! Turns out she pushed on the top of it to keep it from tilting over, and that was enough to help it slide off the track right before it was too late. Such a butt pucker moment! Ugh! Lol She takes pride in the fact that she saved the motor from crashing into the ground/Supra (even though I told her if anything goes bad or falls just move out of the way, don’t be a hero), so I was obligated to disclose that event!
Whew....alright motor in one piece still, in she goes.
249019
249020
It’s around this time we took a trip to San Diego for summer vacation (All of our first time to California/a real beach, had a blast). When we got back, all of the parts I had powder coated were done!!
249025
249021
249022
249023
249024
249026
249027
I absolutely loved how they turned out, other than a hiccup with some threads being media basted so I had to chase them to repair, minor fix and the owner of the shop offered to compensate for the issue but I declined since I was otherwise happy!
Kappa Check 1 2
Discussion Starter #70
I few more pics playing with the light, the illusion violet shows up as purple/blue violet under white/incandescent light and shoes up as pink under yellow/amber light, really cool effect!
Under white light:
249029
Yellow light on left, white light on right
249030
And cool example of how it transitions when under both lights, check out the gradient/transition on the spark cover
249031
249032
One of the lines off the fuel rail
249033
Oil cap in this pic that I decided not to use, looks to cheesy/cheap.
249034
Kappa Check 1 2
Discussion Starter #71
I picked up a few more parts. Fuel lab FPR and Vibrant catch can (inspired by Nick S)
249037
249038
Snapshot of my fuel line routing, not the best but definitely not bad! Out of center of fuel rail return, through flex fuel sensor, through FPR then back to the fuel hat/tank.
249036
Swapped out the stainless throttle cable for basically the same thing but black one from PHR
249039
Installed the Milspec firewall plate and connected harness
249040
249042
I got tired of seeing it in a deconstructed state so I threw on the fenders and hood, believe it or not this lit a fire under my butt seeing it like this!
2.5 years of dust at this point
249043
Water neck painted
249044
bumper and headlights on for the hell of it
249045
Kappa Check 1 2
Discussion Starter #72
More work done by the welding buddy! The bungs at the bottom left are on the midpipe to use as vac source for catch can (I know it’s hit or miss, decided to give it a try to avoid fumes)
249046
Installing the BOV and I/C piping
249047
249048
Oil return
249049
249050
Trimmed the bumper slightly for clearance, I actually really like the look of the bumper conforming to the I/C pipe, call me a ricer lol ??‍♂
249052
249053
249054
Kappa Check 1 2
Discussion Starter #73
I’m just going to rapid fire post pics from here on out to speed this up. Spending my time off trying to get this thread up to date!
249058
249059
249061
Built bracket for catch can
249062
249063
249065
249066
Kappa Check 1 2
Discussion Starter #74
249067
249068
I have to type for this, great friend Eric Lam (MKIII_hater I think he is on here) definitely did an awesome job on rebuilding the diff, new ring/pinion, new seals/bearings, and OS Giken 1.5 way. I cant thank you enough brother!
249069
249070
249071
249072
249073
249074
249075
Kappa Check 1 2
Discussion Starter #75
249076
249077
Measuring using one of my favorite whiskey bottles lol. It was either this or wife’s kitchenware, I didn’t want to die that night so I got creative ?
249078
249079
249080
Wife insisted that I smile since I waited a few months for the diff to get done and it was the last major piece of the puzzle lol
249081
Diff in! I know, the bushings....this is so I don’t take any longer to get this damn thing on the road! I’ll change later on if/when needed.
249082
Wife also insisted I have a glass to celebrate! ? from here on it’s a few more bolt on parts/ simple things and the car can touch the ground for the first time in 3 years!
249083
Next up the driveshaft
249084
Kappa Check 1 2
Discussion Starter #76
Geo from Realstreet told me these were rare/ getting hard to find? Studs from output flange
249086
ARP extended wheel studs, really glad I did these.
249087
Midpipe with scavenge lines (-10x2) attached, these come from the sealed catch can.
249088
This pic should clarify the routing of my ventilation lines
249089
249090
Dilemma: HKS Ti doesn’t mate up to the midpipe for obvious reasons (not using adapter that mates to factory midpipe), so once again I’ll go pay Matt (welding buddy) a visit once the car is running.
249091
Lovely helpers assisting with bleeding the brakes and clutch line.
249092
249093
Kappa Check 1 2
Discussion Starter #78
Bought a battery to give he car power so I could install the driver seat! (Only thing I didn’t do this build that I wanted to other than DSS axles and maybe intake mani)
249094
Checking out Stu’s work and BTI gauge
249095
249096
Hard to capture the gauge cluster woh an iPhone, but they are crystal clear in person
249097
249098
Still need to do the ODO mod to make it white
249099
Aaaaaand she’s landed. Wooooooohhh!! Car may need to come up a bit, I didn’t adjust coils for new wheels and tires yet.
249100
249102
249103
249104
Boost Junkie
Looking good!
Steve
Kappa Check 1 2
Discussion Starter #80
Well that pretty much brings us up to date as of a couple days ago! All that’s left is loading the base map from Alpha on, he will be handling the tune via remote, and before start up I’ll be priming the engine with a melling oil primer.
If you made it this far, thanks for checking out the thread! Car needs a bath BADLY, I’ll post back up when it’s clean and running with video ?
-Rich
249105
249106
  • Like
Reactions: Shady 2jz
