Motor has been running like shit this past weak.
No idea why.
Did a compressor test, 145 across the first 4 cylinders. Then the 5th and 6th were at 30 psi.
So now the car is officially down for the new motor.
Some of the tricks going on inside the motor, are the drilled coolant hole in the head, engine girdle, engine scrapper, and the shimmed oil pump.
I'm also considering getting my main and rod bearings thermal coated as well.
I will keep you just posted
No idea why.
