While I was having fun doing autocross a few things quickly became prominently a hold back you could say to making progress. I quickly got to a point where I was outdriving the car, and this was primarily due to, the amount of body roll present with just having old coilovers, the factory worn out rear diff not doing its job as an LSD allowing for tire spin on the inside wheel, and a combination of the 3.73 rear end and the somewhat laggy driftmotion turbo causing the car to always be very very far out of the powerband meaning I was pretty much just cruising around the course. I attempted to swap a 3.91 out of a pre89 turbo car into it and it helped, but the turbo and the worn out differentials kept coming back to bite me. I decided around June after a few months that I was going to throw a set of swaybars in it to see how that would help. After doing some research I ended up settling on a set of suspension technique swaybars. I liked the ST bars due to the rear being adjustable and them having good reviews from other owners helped. Since the post 89 cars all have plastic rear swaybar endlinks from the factory I got 4 new moog swaybar endlinks (they are very very heavy duty built items compared to stock), and threw them on the car shortly there after. Got these sleeper designs radiator brackets in as well and threw them on to get rid of the factory stamped steel brackets.
The only picture I seem to have is of the stock one (on top) vs the ST one (on bottom). You can see how much beefier the ST bar is, and it was even more so of an obvious difference when holding the bars, both the front and rear were much heavier, I'm sure due to increased wall thickness. So I was super excited to try them out! Let's just say they were very well worth the money! Now the car didn't handle like an LFA, but the difference was very prominent, so back to autocross I went. Went back to autocross and found that not only was the car much more flat during cornering but it was also much more willing to rotate when needed using the steering wheel, which helps a lot on a little autocross course with decreasing radius turns. Now that I had done this it was time for a new major event for the car.
