I had a Thermal 3" system on my civic and it sounded nice. Deep not ricey.mrsc3 said:Anyone had any exp with these mufflers? I want a good free flowing quiet muffler. I'd get the sp but the huge bazooka canister would look horrible on the sc.
^^Thats how my JIC is at idle but at WOT its got a nice growl (as long as the silencer is in)SV650s said:my dual dunks on my SC are not loud at all compare to stock exhaust.. I have stock header, but after the header flange is nothing but the two dunks..and open axle-back is louder than the set-up I have..you can't hear my car on unless your ears are by the cans.
So are you actually running stock cans ?dejacky said:I also like my turbo sc300 quiet. It's actually freakishly quiet until the wastegate opens during WOT :bigthumb: .: I used a 3 inch heatwrapped downpipe, 3 inch mid-pipe with flex section connecting to stock sc300 Y-connector. Mid-End July dyno results will tell me how well this setup flows. The turbo does help muffle the exhaust sound, but the stock resonators and mufflers make the car practically silent (especially when idling). I cannot stand the droning, rumbles, and overall loud exhaust setups, esepcially during long road trips.
I would ideally like it as quiet as stock but there is just too much power to be had by ditching the stock cans.dejacky said:Stock mufflers and stock resonators.![]()
I've heard that is debatable. If I'm able to acheive higher than 400rwhp at 17psi on my setup, then the stock cat-back exhaust flows good enough for me.TooJayZee said:I would ideally like it as quiet as stock but there is just too much power to be had by ditching the stock cans.
True, true. Im aiming for a little higher numbers. The only reason I even say the stock exhaust licks ballz is that on my honda with the pea shooter exhaust I was only making 260hp and when I removed the test pipe with no other mods I got 308. I'm guessing that since the lex's are so quiet they must have some major restrictions. I could be way off, who knows.dejacky said:I've heard that is debatable. If I'm able to acheive higher than 400rwhp at 17psi on my setup, then the stock cat-back exhaust flows good enough for me.
I want something loud when i pick up my friends, I just want something quiet for the copsmrsc3 said:If I had mufflers that big, I better have something to back it up. I don't know about you but I want something quiet when I pick up friends and family members.
