8
87Tmk3
·Guest
I don't thinkl the wheel is the problem. It looks the rubber is to big. If you are running 18's you need a 275/30/18, not a 275/40/18. With the 40 on the rear you are about 3/4 " bigger than stock.
Well, he is correct, the wheels do fit your car. The problem is you are running too big of a diameter tire. Everyone else running 18's usually run 35 series rubber. If you don't want to roll the fenders, then you need to go to a 35 series. If you wanted more rubber in the back you should have gone with a 17" wheel.QWIKSTRIKE said:When I went back to challenge him about his advise and gaurantee he got hostile and said too bad Iwas stuck. ....Should I give negative rating or what?
When I say stole a rim I mean he opened my car door and grabbed a rim and ran with it!
I was looking for that reply GooD PoinT....87Tmk3 said:I don't thinkl the wheel is the problem. It looks the rubber is to big. If you are running 18's you need a 275/30/18, not a 275/40/18. With the 40 on the rear you are about 3/4 " bigger than stock.
I have posted this probably 10 times already, this is definitely a Search item!2JZ_MA70 said:We need a tread that would clarify the diferent offsets and tire sizes that would fit on the MK3 because it is such a big issue...
