hey guys,
i blew my stock twins for some unknown reason and have decided that i want to peice together a small single kit that can run on stock fuel and a stock auto tranny. i was just wondering what are the main components that i would have to purchase in order to go single. thanks...
i floor it and my car goes no where and my boost gauge reads no boost under pressure.
feeding your habit
sounds like you need to do some more research. They may be fine and you might have a bad actuator, clogged cats, etc. BTW, a good used set of turbos should run you less than $600 including gaskets.
Not easy to replace, but if you dont know the car well enough to know if the turbos are bad, you might find the install challenging, never mind what you will think of the tuning.
-M
