I'll nevAr go single!
Ok, speedo is off, want to correct it with a tire size change if possible.
1JZ with R-154 and 4.30 Diff. Trans thinks it has a 4.10 diff, Says G294 on the firewall plate, correct me if im wrong on that.
What could I change my tires to to help correct it? I'm getting new ones soon anyway so no would be the time.
Moderator
do you have the old tranny? Swap the damn plastic gears.
How are the FAL's working for you?
225/50/16 factory size currently.
I dont have the old trans. And I read before that the gear thing mite not swap from a W58 into a R-154, thats why I bring up this question.
FAL's going 1 year strong with not a single issue (But only 2.5K miles in that time, I dont drive it much)
Your speedometer should be reporting about 5% slower than actual? To get it reporting properly you need smaller tires. 4.878% smaller to be exact.
225/40/16 will get you close, the speedo will report 2% higher than actual.
235/40/16 will have the speedo reporting about 1% high.
215/45/16 will have you about as close as you're going to get.
And no, a R154 sending gear won't fit the W58... it's too small. However, you might try contacting the folks at MarlinCrawler, they may be able to find a compatible gear that would work.
