1 - 20 of 60 Posts
Hardtopper
Does anyone know where I could get the threaded rod so I could screw the oil filter directly to the block? I know a couple of guys on here remove the OEM oil cooler... thanks
Hardtopper
Appreciate it but I don't think it will move the filter far enough to clear if there was even a change. I know someone out there knows where to get the threaded rods.
Inline for the win
Is it just a close nipple of a metric thread?
DP
Inline for the win
I've never seen one myself but I would imagine it would be a 3/4- 16 close nipple:
Titan charges over $100 for it... :rolleyes:
Go to a Parker store, grainger, mcmaster etc... That is like $10 fitting...
Hardtopper
Discussion Starter #8
found a project car threat(but can't find it again). there he showed a bolt from ford (e8zz-6890-a) that should fit. going to buy this myself
Thank you!! I did some searching and it is infact what I need
G-14 Classified
Dr. Jeff Lange
I would think that 90404-20173 should work perfectly for this as well. It's the union bolt from a number of engines (including the 7M-GE).
Jeff
6 speed
so with the ford threaded rod deal, you eliminate the stock oil cooler assembly. so now your oil filter seats against the block now, correct? what about the N/A filter assembly vs the ford threaded rod? anybody actually notice a increase in oil pressure after this? or notice any diff at all?
Hardtopper
Discussion Starter #16
Does anyone have a picture of the NA filter assembly vs the TT? I am curious at the difference in location.
G-14 Classified
d00d, come by the house and look at the RHD N/A...doooofus
Yeah, I'm kinda in the same boat. I don't know if I want to buy a N/A assembly or going the threaded rods route..
G-14 Classified
1 - 20 of 60 Posts
