I have a jdm throttle body and I was wondering if I was able to delete the coolant ports from the front and then just connect the two hoses or make one. I don't see why this would cause a problem can someone correct me if I'm wrong
It is singled yes, and the car never sees winter and hardly sees any cold weather so I don't see a point in leaving them if they can be removed
Master Shit Fixer
I think they are there to prevent icing of the inside of the throttle body in cold, damp weather. Airplanes with reciprocating engines have a "carb heat" function to prevent the same thing.
I believe you are correct in what they are for, to keep the butterfly's from sticking in cold weather, I don't drive the car in the cold which is why I don't see an issue taking them out I just want to make sure it isn't going to harm anything
I don't have mine hooked up.
