1 - 13 of 13 Posts
I was wondering what purpose it serves myself...cuz Hey, that's extra WEIGHT I COULD REMOVE!!!! heheh, but really, whats it for?
So I should probably clean it and get it working as opposed to just putting back on like I did a while back, mine's jammed solid. Or not to worry about it?
Dr Wheelspin Rh.D.
If the car doesn't stall after you put it in neutral from high RPM's then the system is working fine and I wouldn't suggest touching it. I'm not sure how much that filter actually does compared to the valve that the throttle actually hits. Weight savings from removing that would be negligible. You'd save more weight driving around with only one sock.
sockless it is!!!
easier than taking a few pounds off me! I'm so fat......:(
and I'm not gonna mess with it probably. Me and a friend are gonna take the intake off today and search for a vacuum/boost leak that's hiding from me. Gonna start a thread really quick asking for advice.
***ified?
the filter keeps the dashpot clean and helps to restrict airflow so that your plate doesnt slam shut. If you dont like it take it off.
Yes you could take it off, but the return spring for the throttle body is attached to the dashpot. What would you do for a return spring if you took off the dashpot? I dont' think it's a good idea to just tell someone to remove something without letting them know at least a little bit of what will happen.
Discussion Starter · #10 ·
Hey, man its all good....besides....for the itsy bitsy amount of joy I would derive from removing that think it's nowhere near the amount of work....and also I do realize the spring is attached. I wouldn't have just hacked it off and then been ..."oh crap" Cool that you look out for peeps like that though, I run across people that would just break it off and be s.o.l. at my job at Autozone....I do my best to prepare them, and I think its cool you do to.....
Thanks Anyway...!
***ified?
I didnt say remove the dashpot. I said remove the filter.
1 - 13 of 13 Posts
