1 - 1 of 1 Posts
SupraForums Sponsor
I now have the RPM hooked up to my wideband and it is working good. I have a question about the throttle position sensor though. It looks like that when I hook it up my full throttle only shows 46% or so on the wideband while the AFC shows 100% (correct). I am using the same wire the AFC uses to measure this as well...does this sensor not go 0-5V?
As far as the turbo pressure sensor...I tried to use the one on the ECU that you would normally wire into the BCC white wire, but not sure exactly what it is doing. Is it a 0-5V input as well?
Any help would be greatly appreciated.
1 - 1 of 1 Posts
