1 - 8 of 8 Posts
Het everyone I just put in a new fuse box/harness. thats the only harness I changed not the engine harness.
Im getting codes 41, 47 im not getting any voltage to either tps.
Is there a plug that could be the cause, the car starts and runs but its in limp mode because of the error codes.
I dont know if its the computer or what? im getting frustrated trying to figure this thing out.
Code 41 and 47 only display when there is an open or short in the VTA signal circuit of the TPS which is 41 and 47 is the sub-TPS.The trac ecu will also give you those codes.You need the manual to check resistance at the sensors and voltage at the ecu.
so it could be the trac ecu?
It uses the tps and trac tps?
Should I dissconnect the trac ecu and see what happens?
i forgot to update, I found the problem it was the ECU.There wasnt enough voltage going to the tps.
1 - 8 of 8 Posts
