1 - 9 of 9 Posts
EchoDeDupra
watch out... they might hit you :)... lol...
well, ive been throwing a random code that comes on, then comes off sometimes.... so I didnt worry about it. Well, I finally got around to checking them, and this is what I found.
24- Intake Air Temp. Sensor Signal
27- Sub Heated Oxygen Sensor Signal
31- Mass Air Flow Meter Circuit
24- this is the one i'm worried about
27- My wires were cut on the O2... and this affirms my theory that I wired it back together wrong
31- I blew my intercooler apart, and had to disconnect the MAF to drive home. But it's since been fixed.
So, now I'm going to reset the ecu, which should clear 31, and I assume 24 and 27 will pop up again. Tommorow or later on today, I'm going to re-wire the O2 sensor which should fix 27. 24 is the one that I have no idea what to do.
Thanks in advance guys for any information you have.
The intake air temp sensor is inside the MAF. So when you disconnected the MAF you also disconnected the intake air temp sensor. Resetting should clear it.
EchoDeDupra
awesome man... ill fix my o2 sensor tommorow.. reset the ecu.. and check again
I reset my ecu this afternoon... started the car.. and it gave me a light... but thats the o2 i assume
Very Senior Member
Wow - I'm surprised it drove at all?
How did your O2 wires get cut?
EchoDeDupra
well... i ran a max boost of 0.00 bar (of course :))... the car ran pretty shitty... tons of lag... etc. etc.
But it got me home from the race...
EchoDeDupra
as far as the o2 sensor...
a friend of mine tore them from not taking out the o2 sensor when he was trying to take off the downpipe.... i.e- took it off the manifold... pulled odwn.. and rip
then he butt connected fixed them.... and then when I got a new tranny... they notcied that a few had come loose... when I got underneath... it looked like shit from my friend (some friend right?)...
well... I just need to rewire them again :)
Very Senior Member
Well, depending on where the wires are broken, that might be a fun fix.
I replaced my O2 sensor Saturday and that was a royal PITA.
1 - 9 of 9 Posts
