Trev
Hey Guys, I have no friggin' clue as to this Tial External wastegate hook up. Do I weld a flange to the manifold, hook it u there, then run another pipe from the outlet of the WG down to the DP? I have seen some WG that are located where the charcoal canister is....why are they way over there? how does this affect performance? Trev87supraturbo
The Beginning
What kinda turbo application are you doing this on? The Wastegate will go after manifold(Except for an aftermarket manifold.) and before turbo. If you want it to be quite under boost then the dump tube will have to be rerouted back to the downpipe, but if you like it loud and I mean loud then just get a dump tube that would let exhaust gases out to the atmospere below car.
Trev
it's a 62-1, .74 a/r, p-trim----it will bolt to the stock manifold. I want it quite, so i will dump it back into the DP. what kind of wekding is required since the Ex. Man is cast iron? will the Tial flange weld to this? do I weld it as close to the cener of the Ex. man. as possible?
Trev87supraturbo
