1 - 20 of 28 Posts
LEADED FUEL ONLY
Does anyone know who holds the tighter piston to cylidner wall clearance. I'm looking for a forged piston with minimal slap problems at cold startup.
///M3 > MKIII
al
You might wanna get in touch with Jt from MAXX autoworks... he has done alot of 7m's using both brand pistons... think he generally recommends Ross. I remember reading a couple posts on piston slap with the JE's.. also someone commented on the slap in the product review on suprasport.
MAXX's # is (253) 661-0118
what will the future hold
I have been using wiseco pistons for two years now. My car has absolutely no piston slap. I think that a thing of the past. It once was a deal with silicon content but thats long gone. Just get a set of pistons you like and run.
Will
Turbonetics..faggot asses
I've got JE's in mine and mine is quiet as hell, no knock , no slap, just a nice "mmmmmmmmmmmmm"
I have JEs and I can hear it make some noise when cold. I set clearance to JEs recommendation of 4 thou measured half an inch up from the bottom of the skirt. After a minute or so, no noise at all.
i <3 fitness chicks
I'm not sure on clearances, but i would not go with the JE pistons anyway. I am having my block rebuilt with Ross .017 over forged pistons, and my guy was telling me that JE's are a no. Where the 4 grooves are, the area between the grooves and the actual end of the piston is quite small, so it is likely to crack there. Genna had JE's and his pistons cracked right there. Ross or Wiseco's are the way to go, he told me. Hope that helps you somewhat, but i would stay away from the JE's.
- John
Edit - IF you do decide to go with the Ross pistons, check this place out. $520 shipped for mine and they came with rings and pins.
http://www.importperformanceparts.net/
Alan,
Not sure which brand can run the tighest clearance, but here is some good general piston info.
http://www.se-r.net/car_info/engine_performance_tuning.html#Pistons
Mike Kojima wrote this article for SE-R.net, but it generally applies to all pistons I guess. He also wrote a series for Sport Compact Car called "Suck Squish Bang Blow". Awesome series of articles on engine inter-workings and there was a lot of really good info on pistons.
Dale H
87T
Impeller Head
I think with the materials piston manufacturers are using nowadays, you can't go wrong. I have JEs and they don't slap at all, even when cold. Alan, why not go big bore with HKS? :)
LEADED FUEL ONLY
Discussion Starter #10
Thanks for the info guys. Looks like I'll lbe going with Ross pistons due to cost.
I *greatly* appreciate the link john. :) I'll be ordering soon I think.
***ified?
my JE pistons are set to .003, and installed with file fit rings. They sound beautiful. I paid just a little over 500 at flatlanderracing.com
that for 6
unless the 7m-GTE lost 2 cylinders and toyota forgot to tell us ;)
/sidenote:
What is the most common bore over?
.017" ?
Ross has a set of 3.285" bore pistons.
Reason for the q. I am about to embark in the rebuild of my 7M.
And at 500 bux for all six. I want to make sure i get the right one.
Also
Knife edging the crank. A big NO on the inline six crank if i remember right. Confirmation?
Good info guys!!
wastegate hose is pulled
That seems kinda tight for a turbo motor. Was that JE's recomendation? I got my Ross pistons today and they recommend .006" minimum skirt to wall clearance for a turbo motor. May be a little slap when it is cold. No big deal, my WRX does that from the factory. The deep skirts on the Ross pistons may keep them quiet though.
Ross pistons include rings, JE's do not. ;)
Tried to post a pic, but it woln't let me (yes I know how to link them). :rant:
if ross recommends .006 clearance and the ross piston is 3.285. Then I need to bore the cylinders out to 3.291? Please correct me if I am wrong :)
1 - 20 of 28 Posts
