1 - 3 of 3 Posts
· Engmaineer
Hi,
I need some Tilton Install parts:
A new Pilot Bearing, A new rear main seal, and ARP flexplate bolts.
I'm not sure what the length is though:
http://www.horsepowerfreaks.com/performanceparts/Toyota/Supra_MKIV/Flywheels/Flywheel_Bolts
They should be the exact same length/size as stock flexplate bolts from a MKIV Auto (if you have one around to measure)
Can I get a total for shipping to 77539 (Texas)
Hi Sir,
Please check your PM's, I am in need of a bit more information so that I can be sure to get you the exact parts you are after.
Regards,
· Engmaineer
Hi Sir,
Regards,
I sent you a pm back. I guess I should of clarified better. The clutch is a 93-98 Tilton Carbon triple 7.25" Clutch.
The pilot bearing is an OEM bearing for a supra I believe.
The Rear Main Seal is the OEM seal for the supra.
The ARP flexplate bolts is the exact same size of the 93-98 Auto Flexplate Bolts. I don't have one here to measure, but I believe its M10x1.25 (not sure the length)
1 - 3 of 3 Posts
