Its a pretty simple job as long as you take your time. Plus it gives you a chance to change your coolant and serpantine belt. etc.. amonth other things associated with regular maintenance.
Probably the most difficult part of the job is removing the crank pulley. Once that is removed its a matter of making sure all your marks line up properly and bolt everything back together.
good luck
chris
good luck
chris
