1 - 8 of 8 Posts
ok i changed some sealsa couple weeks ago. the cam seals and crankseal and oil drive seal. my dads friends was givin a hand and he put the timing belt back on. we finished the job. put everything back on. and since then i have been hearing a whining noise coming from under the timing cover. possibly to tight? also would the timing belt being too tight cause to overheat?
theres a spring that holds the tension at the right place but theres a bearing inside the tensioner. did you replace it when you did the belt? the bearing could be bad.
like 8 bucks from napa
alright
also do u know if b4 you loosen the timing belt even just a little, if u ave to make sure ur at tdc
no it doesnt really matter are motors are non interference so you can spin the crank and you wont damage any valves
1 - 8 of 8 Posts
