You guys might want to check out www.pocketlogger.com It's what I use for my DSM and it has all the datalogging features plus you can use a palm pilot for the datalogging. Also you can overlay the graphs like you want to be able to do.
I'd agree with that, more octane seems to be required....looks like mid teens under WOT there eh? By all means post some more results - if you log again with higher octane.stoker6 said:Someone posted some data about the OBDII meter software a while back, but nobody ever posted the user interface. Thought I'd share some data from a pull I just made.
T78 @ 1.6kg/cm2 ~22.7psi
~100 octane from 33% toluene/93 pump
Ambient temp mid/upper 50's
RPM and Timing sampled at 1 sample every .66 seconds (ideally).
AFR 11.2:1-11.4:1 (bit rich)
I suppose this looks about right. I'm going to turn the EBC off and run off wastegate after resetting the ECU. I'll post back the results as I expect a little more timing advance. Around max torque the timing gets very conservative and increases as torque drops off. Looks like maybe the toluene isn't quite enough octane for 23psi.
Their website says the OBDII logger will work for 96-98 Supras.Grumpy said:I inquired about the pocketlogger last year. I got a short reply saying that they didn't have applications for the Supra and that they weren't thinking of making one either.
Don't waste your money with that stuff. Get some C16 and mix it to the octane that you need.I need to get another drum of GT 104 and do some logging...
I forgot to mention for OBDI cars. My car is OBDI. I think I will try and plug a DSM datalogger on my car to see if it's compatible.Chicago///M3 said:Their website says the OBDII logger will work for 96-98 Supras.
Toluene isn't leaded. That can matter a *lot* to folks who run the stock O2 sensor like me. Beyond that and finding a local source for C16, it's no contest.AZMongoose said:Wow, Toluene is only 94 MON? Basically that tells me that its rather usless and a higher octane number could be had with a 5 gallon of pump to a 1 gallon of C16 mix which would cost about 2.65 a gallon...how much does Toluene cost again?
I paid $175/55 gallons. Worth a try anywayAZMongoose said:...how much does Toluene cost again?
Ahhhhh...thank you earl.earl3 said:peak torque = peak cylinder pressure
