1 - 9 of 9 Posts
I tried to use the calculator on the site but i don't know all the info because the rims were made to be on a s500. The rims fit and adapters are being made to push the offset out currently. The rim size is 19 x 10.5. The tire i am putting on hopefully is the Continental ContiSportContact 2 Vmax 315/25ZR19. These tires stand 25.1" tall. The car is currently on stock suspension with eibach springs. Will i have to roll or cut the fenders to get these to work?
I run 315's on 11.5 wide wheels with very little rubbing which doesnt hurt the tire (only one one side) I also had cut the lip on my fender off.
Lawrence
Let's go Phils
I have 315/25/19 contis on my 19x11's w/stock suspension. No rubbing whatsoever. I'm planning on lowering very soon, hopefully I'll be able to get away with it.
295/30/19's on 11's and when I lowered it, I had to roll the fender's. Good luck.
How much did you pay for them? How are they? Do they wear quickly?
Discussion Starter #6
did you lower your car yet?
Put them on, If they rub then Cut the fender lip Off or Cut the wheel spacer to push the tire in some ...
1 - 9 of 9 Posts
