1 - 8 of 8 Posts
I have a set of 315/35 BFG drag radials on Volk TE37 17 x 9.5 wheel. Only the driver side tire rubs the fender. Could this be an alignment problem or a problem with the shock/coil?
Turbos and Tattoos FTW
could be that you the driver is weighin down your side of the car.or the shock
I had the same issue when I had a passenger of similar weight in the car. I weigh about 160 lbs.
I checked with a wheel alignment shop and it turned out to be that I have a blown shock.
1 - 8 of 8 Posts
