Basically I am running 18x9 fronts and 18x10 rears. The problem is the manufacturer says to use 285/35 on the rear and 245/40 on the fronts. I would like to use the BF Goodrich g-Force T/A KD now they have the fronts 245/40YR18 but the colsest they have on rears are 285/30, 298/35, and 265/40. Now with 10in. wide rears how wide can I take the tire without rubbing or anything?
Thanks Steve for your input.
I figured I have the Blitz Technospeeds 18x10, I think 47mm offset, so they won't fit. But maybe I will roll the fenders a little bit to make them fit. Plus I still break lose my 285/35R18 HTRZ II easily in 2nd gear so I wanted a 295/35 with better all around performance.
The reason I want a 35 sidewall is cause in New York the roads are so bad that I don't want to damage the rims.
