Phantom Flipper
I just bought some new rims that are 17x8 and 17x9 with a 35mm offset. What's the best size for this setup?
1.5JZ Turbo Supra
i would go with 245/45/17 front and 275 40or35 rear.
Phantom Flipper
Thanks for your responses, fellas? Any other suggestions?
And what's the reasoning behind having a higher sidewall up front than in back?
way over budget
the second number is a ratio, not a specifid height. wider tire on the back means the second number should be a little smaller so that the sidewalls are close to the same front and back.
You need to research, all tires and tire manufacturers have different specs for which wheel sizes their tires are designed to go on.
