Titan fuel system which one ?
  • Titan Fuel System with 1 extra fuel pump/1000cc Injectors etc....
    Votes: 3 23.1%
  • Titan Fuel System with 1 extra fuel pump/1200cc Injectors etc....
    Votes: 3 23.1%
  • Titan Fuel System Triple pump w/1200cc Injectors etc...
    Votes: 1 7.7%
  • Titan Fuel System Triple pump w/1600cc Injectors etc...
    Votes: 6 46.2%
Which fuel system would be the best choice if running a 76mm turbo and later on upgrading to 80mm or 88mm turbo in the future ?
t-dogg said:
triple pump with 1600cc injectors. and you will need to go bigger on the feed and return lines to
What he said. Unless they have a new kit out there that isn't advertised on the site yet. I had the one with 850cc injectors and just got rid of the whole shebang for a new setup that's coming. If you're planning on upgrading to the 80 or 88 later you definitely should just start with the 80 now and go with the triple pump and 1600cc's.
James
Motec - Race Smart
The triple pump system system with 1600s is what you'll need. It is a -10 feed split into two -8s to feed the rail with a -6 return, aeromotive regulator, weldon fuel filter, titan fuel rail and triple pump hanger with three walbro pumps. This setup will support 1400hp, although I would recommend going with a Weldon pump over the triple walbros at 1300+ hp.
-Darin
Does anyone have pics of a triple pump set up?
