Titan Motorsports Pro Drag 3.2L Aluminum Rod stroker kit is for the serious drag racer looking for max horsepower to gain that extra edge and lower their ETs. This is a race only setup, if you’re thinking about using this in your daily driver or weekend street car think again, we’ve got plenty of other setups designed for your application. This kit has been proven in some of the fastest 2JZs in the world and comes complete with everything your machine shop needs to install minus main bearings and recomended Titan Motorsports main caps.
This 90mm Stroke crankshaft, Aluminum Rod equiped stroker kit is designed for high RPM and capable of over 2,000hp of reliable dyno proven horsepower. Included in the kit is a Titan Motorsports 90mm Billet Crankshaft, Oil Drive Gear, Titan/GRP aluminum rods, Custom rod bearings, Titan Custom Race Pistons, Titan Custom Ring Package and Coated wrist pins. If you’re looking for the ultimate track only drag race stroker kit for your 2JZ, look no further.
Retail $9995 shipped
Email me for more info
[email protected]
Do you mind explaining why this is geared towards race only?
Ryan
Ryan
Because you need check clearance after so many passes to keep things in check .
Ryan
Pretty much.. There is more service involved than with a Steel rod setup. Depending on the rest of the setup and is being used in a street car, at least once a year i would pull the motor and inspect everything.
