· Premium Member
I'm currently installing my Titan triple pump fuel system with their billet hanger. Wich way did you guys point the 90-degree fittings? The AN10 seems to a be a VERY thight fit and I'd like to see some pics how you have yours mounted.
Also the AN10 feed has a 45-degree fitting that should connect to the Weldon fuel filter (according to Nero). Any pics how / where did you mount it? To me it would be more convenient that it would have a straight fitting instead of the 45-degree.
Any help?
· Premium Member
Awesome, thanks!!
So that's the 45-degree fitting that goes to the hanger? Titan told me otherwise but I think they said it by accident or I wasnt clear enough with my question.
What's the fitting on the breather line? I didnt get one.
Did you power the pump from the fuel level hangers ground wire? Did you change the wiring to something thicker?
the breather fitting is an 1/8in npt i got from a hardware store....as for the wiring, i didn't feel safe running three pumps through one wire so i ugraded wire to a larger gauge, repinned, and ran two pumps through one wire and the third through the other. Then ground the pumps to the hanger..then hanger to chassis. I don't know if this is the best or most effiecient way but it worked for me
