1 - 4 of 4 Posts
so i took the car for a spin down the street. when i open up wot the exhaust backfires violently like pop pop pop pop loudly then the engine dies. i start it back up and drive it to make sure its ok. i get back on the gas and the same thing happens.
heres the set up. its a cressida with a 7mgte motor, the stock NA ecu, stock 7mgte injectors. was told theres a walbro fuel pump but i never got around to pulling the tank to verify it. i just put in new Autolite 3923 gaped to .30
i dont drive the car, i just start it up and move it around to get other cars in the garage or around the block to make sure its running ok. after a few weeks of starting the car a couple times a week. the plugs foul and i have to replace them. im on the third set of plugs. when i pull them they are black and covered in unburnt fuel.
at idle there was quite a bit of black smoke comming out of the exhaust. so this morning i removed the Jtube and it still has a little bit of black smoke but definetly less than before.
does this sound like a fuel problem since it runs rich and i dont have any means to control it? thank you
I don't know how its running at all with a GTE electronics set and a GE ECU. Get a GTE ECU, then come back and let us know what it does.
Swap your electronics, it's dumping fuel according to the n/a injector size, and since you're running much larger injectors it's running crazy rich.
1 - 4 of 4 Posts
