21 - 40 of 78 Posts
Crappy cell phone pic, I never bothered to download the files from the dyno since it was in my place of work.
1.5jz, stock compression, Precision 6265 journal bearing, .81 housing (drewgo style manifold for the guy that asked), BC 272's, 3 inch Tanabe Hyper Medallion, Power FC, 1200's on E85, creeping to 28 PSI, 3rd gear pull (would probably spool a little earlier in 4th, just tend to do tuning in 3rd because it's easier on the car and the dyno brakes)
686hp, 570tq, Dynojet STD correction (made 669 at TX2k12 the week after with SAE correction factor)
Edit: Found the video, you can hear the boost controller freaking out (big dip you see on the graph). Title says 1jz, but I may or may not have been sandbagging about the motor setup a little bit for TX2k12 :)
I'll dig through the dyno computer in a few days and overlay some graphs from this same turbo when I was on my 1jz block without cams just so people can see 2.5 vs. 3.0 bottom end side by side. No idea what turbo Albert is running, but if these dynos read in the same ballpark, my car makes over 200ft lbs of torque more than his at 4500rpm, even though his peak TQ and HP are higher. These are the little things you don't think about when you say "oh, I want to make x horsepower".
Formerly Lone Ranger
My shakedown dyno tune. My mods are 2jzgte, BC 264 cams, BC springs and retainers, Borg Warner 83-75 turbo, treadstone cast manifold, 3 inch downpipe, Greddy SP exhaust, 800cc Sard injectors, walbro 400lph fuel pump, HKS DLI and AEM EMS. Pump gas tune on a mustang dyno. 529whp, and 419wtq at 18.8 psi.
879whp DynoJet, Might as well put me on the list. 1991 Hardtop Built 3.0, 2JZ-GTE, Precision GT45-7685 Billet
Discussion Starter · #25 ·
everyone is updated. i will come up with a better way to list them this weekend or something, i dont like how it looks. anyone with any ideas lmk.
Captain Slow.
Shit I need to get my dyno on..
Coming for that #2 spot!! ;)
I'm surprised Ron isn't on the list with his 844 on race gas and 704 on pump.
Also, GrimJack (Dave) with 568, even though a bit lower on the list of the 2JZ swapped MK3s, but still up there!
Discussion Starter · #29 ·
im not searching thru everyones on the internert for there dyno numbers. i know ron has made power, i just dont have time to do that for everyone, i know alot of people who should be on the list.
I agree with Sean!!! If they want their name on the list, they need to post or have someone posted for them..
Resetting
Maybe separate them by region. Then when that's separated list Year of car or something to that effect.
Is this with the TS .91 housing?
I actually made 619rwtrq not 614. If someone can change that... I know the 1jz need all the help they can get on torque lol
Impeller Head
I don't have proof of my dyno runs anymore. Those things disappear during my drive home from the dyno :)
1JZ record on MKIII chassis... Time to update Turbobozzer
This was done at SP mustang dyno which has been proven to read lower than a dynojet
21 - 40 of 78 Posts
