1 - 20 of 30 Posts
ur moms favourite
x X CLoud X x said:
trac fuse
what he means to say is that on your USDM car (assuming it is), all you have to do to remove the speed cut is pull the trac fuse.
a supra..fast..hahaha
InvisibleMonkey said:
what do you have to do on non-USDM supras then?
yeah cause i have a J-spec ecu and i don't have trac with my built auto, and i still have the NA rear gears, so my car is shutting down at 120 mph... just wondered if anyone had used the Greddy Speed cut limiter or the HKS one...and wanted to know if they worked...
Boost4fun
^^ :urowned: ;)
Yeah first that, and even if it is the limit it would be nice to have it removed for track etc...Or? :stickpoke
BTW what is the cost for such a speed cut defencer just for my info?
Gerd
Discussion Starter · #10 ·
I have found the Greddy one for about $59.00 and The hks one for about $155.... that's the reason i was wondering if anyone had purchased either and wanted to know if they worked...
Discussion Starter · #12 ·
like my previous post said.. i don't have the trac system.. i have a built auto so my trac is already un hooked.. and i have a j-spec ecu
ur moms favourite
If you have japspec ecu then you will need one of them, either one will do the trick just fine, so if the greddy's cheaper, get that. I've got the greddy speed cut defender in my JDM tt, works great ;)
Discussion Starter · #20 ·
thanks.. just wanted to find someone that had it and verify that it does work.. i appreciate the help.
1 - 20 of 30 Posts
