Jonathan S said:
Chip,
Thanks for the #s. I'm running 285s in the rear now and should be seeing similar speeds in each gear.
I always wondered why the Supra's redline was 6800 but shifting at 7000 always seemed best.
I did get alot of my problems resolved, a few more minor things and my car will finally be 100%. None of which affect performance, except the possibility of a faulty EGCV actuator
Anway, do you know when Fontana is opening, and do you plan on making a trip down there when they do? I still have yet to run my car at the track and I'm glad I skipped the Famoso drag dag (Carlos with the white 98TT said you were getting a little "frustrated" at the track).
Let me know when you'll be down at either Carlsbad or Fontana and I'll try and make it out.
Fontana opens the weekend of 12/13 January. I plan to be there on the 12th.
Man, Carlos was right. That track was sooo slick I could not run well, my best pass was 13.3 @ 117, and that was not going wide open until the top of 3rd. I had a lot of runs that were much worse, and no matter how soft I was on the gas as soon as I was into the rpm where the 2nd turbo spools the car broke loose and went sideways. Really sucked, but now I know never to bother with a track when there has been very recent rain and the temps are cool.
You were lucky not to go, it was a waste of $65.00 plus time.
(If you know Zo Faridi, his 300Z went
[email protected], I was really impressed by that.)
Also, as far as when to shift, on a BPU car make your first 3 gear changes at 7000, 6700 and 6400 (1-2, 2-3 and 3-4) as indicated on the tach.
