1 - 7 of 7 Posts
Factory Torque Specs Needed!
What is the factory torque spec for driveshaft front & rear bolts? There was red loctite on the rear bolts, is that needed?
How about the flexplate bolt torque?
I dont have a service manual handy - they are getting hard to come by!
Thanks!
Al
OG SF Member #603
Al,
If someone doesn't chime in earlier, I'll get those specs to you when I get home. I'm doing a TT auto swap into my NA.
Scott
book says differential to propeller shaft is 58 ft lbs
OG SF Member #603
Al,
Here's what I pulled from the FSM.....
torque converter x drive plate 25 ft-lb
drive plate x crankshaft 47 ft-lb
propeller shaft x transmission 41 ft-lb
propeller shaft x differential 58 ft-lb
Hope that helps. Let me know if you need any other specs.
Scott
1 - 7 of 7 Posts
