1 - 10 of 10 Posts
Who is running this manifold and on what size turbo?
Will a 67 be able to run intake piping?
Seems like the distributor will be in the way.
thanks
it will. the 4" inlet deff wont clear the distributor without clockin the flange a bit. Some 3" inlets fit barely past.
I have T61 with 4" inlet mounted on my toyo mani and it needs to be clocked...but I am just going to remove the distributor all together and replace with cps since im using the aem
turbo lexus pile
hey whiteblazze i thought you already ran DIS with AEM a while ago? did you change that out with your NA-t setup? when did you go turbo too..last time i talked to you your car was still NA, just DIS with aem.
I ran the DIS on the na with the aem for a few hours for testing to make sure it would work. I am still NA right now, breaking in the new trans, diff, TT brake setup, etc. I'll be doing the NA-T AEM install probably next month when I have more free time.
ok ic.
Gonna probably need to clock the manifold.
Sucks, why dont they just make it right the first time?
probably why they arent around anymore either ;)
Over Medicated
I'm running the Toyomoto mani as well with a T62-1. What I did was use a large 4" silicon 45 degree coupler to get around the distributor then attached the MAF to that.
Hardtopper
I am running the Toyomoto mani with an SP74, no problems here.
1 - 10 of 10 Posts
