Toyota Supra mk4 2jz GE stall's straight away
864 views 3 replies 2 participants last post by  bc2jz
#1 ·
Hiya guys ,My name is antoni im from england and im new to the supra form, i dunno if anyone has / had this problem but couple days ago started the supra up was fine no problems, yesterday when to start it up and it would just stall straight away even if i try and keep tapping the throttle pedal to give it some more gas... theres no alarm / immobilser on it as there was an aftermarket one fitted but was causing problems so i took it all out and was all fine till yesterday.theses are the things ive checked...
ive checked theres a spark from the coil pack,
the fuel pump is switching on and off when ignition is on
but ill be checking the fuel filter, ill be taking the fuel pump out and checking its condition of it , and ill be checking the spark plugs
can anyone shed some light to this..?? is there an inertia fuel cut off..??
