1 - 10 of 10 Posts
TB water line routing & VSV bolt-up location
I've been searching for a while now (forum and TSRM) and can't seem to locate the answers to these ??
1. How to set the TPS using a meter (solved - thanks for the link Jason), and
2. Where do the two water lines that connect to the TB rise through the intake mani? Seems that when I go to mount the TB the two lines tend to bend quite a bit to get the TB in place. I think I may have them routed wrong :(
On a side note - where the heck does the VSV on the lower front end of the intake mani mount to?
Thanks in advance for any help you can provide all :D
It's the rubber hoses that tie into the TB that I think may be routed up through the intake manifold wrong.
Still need an answer on the bolt-up location for the VSV at the lower front end of the intake mani - the one that has two vac lines and one electrical connection.
I love this place
JZS161 Aristo TT
Re: TB water line routing & VSV bolt-up location
Under #1 inlet runner there dont seem to be a clear pic of loaction but this pipe diagram might help
Vacume hose diagram
:rockon:
Thanks again Jason - but that doesn't show the one that is to the front of the EGR VSV. Wish I could post a pic but the camera's down.
1 - 10 of 10 Posts
