1 - 3 of 3 Posts
Fast Enough, Never Is.
Car ran great at BPU w/ AFC, everything was working correct. Sold the afc and the guy helped me take it out. That is when the problems started, I need to find a solution(s) to the problem of my tps and mass air sensors reading 100%. I hooked up the AEM correctly the tps and mass sensor both showed 5 volts each all the time.
wastegate hose is pulled
AEM doesn't use the MAF. As for the TPS, I'd check for a bad connection where the AFC wiring was taken out as a first step.
I know it doesn't use a mass signal. I forgot to mention I hooked up another afc to the car to try and work out the wiring. Has anyone had any problems like this before. Any suggestions would be great.
1 - 3 of 3 Posts
