1 - 3 of 3 Posts
i bought a new tps from a 87 mk3 turbo to replace my tps on my 92 supra turbo. but the inside of the tps from the 87 mk3 turbo was different from my 92 mk3 turbo tps.
does it matter can i still replace it?
They are not the same. You will need a 91+ TPS to fit on a 91+ tb. The starting angles are different. You can open up the TPS and make it like the 91.
thank you. also the 92 throttle body is different from the 90 mk3 turbo. Ok, guess i'll have to get a 92 throttle body with tps.
1 - 3 of 3 Posts
