I've been trying to set my TPS sensor and I'm having some difficulty. From what i have read the throttle plate is suppose to be open a crack and when you apply the vacuum source the plate is suppose to close. Then you set the TPS with an ohm meter and turn it till it deflects. I wanted to verify these instructions cause my throttle plate is completely closed whether i apply vacuum or not and might be the cause of my difficulties. If anyone has some info on the subject it would be greatly appreciated. Thanks
