1 - 9 of 9 Posts
Crazy Member
The stock TPS (Turbo Pressure Sensor) that is bolted to the intake manifold has 1 electrical connector and 1 vacuum line port.... what is the vacuum line port for? and where does it need to run? Is this just a regular vacuum boost source?
I am single, with MAP ECU and all VSV's and EGR removed.
Thanks,
T88 YOU
the port runs off the intake manifold, it has a little filter between it, that is where it gets the reference from
TPS = throttle position sensor
MAP = manifold absolute pressure
the vacuum line connects to the plenum so the MAP sensor can detect the manifold pressure
Old School
In Toyota-speak it is called a TPS. :)
Inline6Performance
Thanks,
I also run Map Ecu and single. I have the plug connected and the vaccum port open.
Mike
Wait, there's supposed to be a filter between the stock MAP sensor and the manifold? Is it one of those bulgy in-line units like the VPC uses?
Crazy Member
You know what guys, after reading your responses... THANKS BTW.
I feel like an idiot... for some stupid reason I assumed that the TPS was tapped into the manifold (too much Beer with the car work) and I was wondering what the hell the vacuum port is for. Now I realize that the little air/fuel filter was the vacuum/pressure source. LOL. My stupidity. :doh:
Cheers,
T88 YOU
the filter is actually a little acorn looking thing that is screwed into the intake manifold, its black.
mike, i would hook back up the map sensor, it controls 6 key functions in the ecu, primarily in fuel control.
2jz powered
The little acorn looking thing is just a gas filter.
I didn't know the turbo pressure sensor on usdm supras had anything to do with the ecu. Everything that i've read shows that its there for boost cut and 9/12v operation of the fuel pump. I've never seen anything that mentioned the ecu using the turbo pressure sensor for any type of fuel adjustments.
1 - 9 of 9 Posts
