I was rolling in my car hard last night (w/ the trac fuse in and turned on) and when I drove the car the next day the trac fuse/engine light and red triangle light on the tach came on simultaneously).
When I shut the car off and turned it back on the red triangle light on the tach was still on then the trac fuse/engine light came on again simultaneously.
I cheked the trac fuse which was not burned out. I pulled EF Main 1$2 to reset ECU. Pulled trac fuse, checked battery terminals and still the same issue.
Car is not overheating, no oil leaking, and EGT looks fine.
Any ideas what it could be? How do I get those damn lights to go off?
Help please
Help please
