21 - 24 of 24 Posts
great this is i was waiting for !!
thanks for shearing
Here is the resistor orientation in the sub throttle connector to not get a check engine light.
Sean @ Induction sent me this when he worked @ Titan via an email years ago
VC = #1
VTA = #2
IDL = #3
now yall need two resistors....a 10k ohm 1/2 watt and a 1m ohm 1/2 watt.
now take the 10k ohm resistor and put it into #1 and #3....
next put the 1m ohm 1/2 watt into #1 and #2....
basically sj told me that when u test the sub-tps when it is opened, you should see 2-10.8k ohm between #1 and #3...(the 10k ohm resistor creates this). Then when u test between #1 and #2 you should see over 1m ohm (1m ohm resistor here). in essence the ecu thinks the sensor is there...and is open....
ill try to post pics....but its basiclaly like every other resistor mod on the supra....ur foolin the ecu by giving it what it wants.....some range of ohms that the sensor SHOULD be sending it.
This used to be a great post...but it looks like Photobucket fucked up most of the useful info that was here. Is there any way to recover the pictures and make them functional again?
Sadly, more and more historical info is slowly being destroyed by stuff like this.
Mind if I do a J?
One of my build threads and at least one of OP (94canuck) ended up on a site called diyauto.com
21 - 24 of 24 Posts
