1 - 7 of 7 Posts
I play hard to want...
I just did a service on my 87 NA auto and I read that it takes 1.7 qts.but it wasnt reading on the dipstick, before I read it I got the car warmed up and then put it in neutral than checked it and still nothing.so I put the rest of the second qt in and than it barely started to read.
Did I do something wrong?
Mark
Dr. Jeff Lange
Total is 7.6qts, but I think with a drain/refill, it's supposed to be 1.7qts.
Maybe you drained out more than the manual expected you to, lol.
Moderator
You have to keep filling it
untill the cold section is filled with the motor running thats just it
So it should be 1.7 qts give or take? :)
Moderator
Give not take bro mine took almost 3.5 :)
*Note* Go Slow and Do not Overfill add a little at a time and keep checking over and over everytime you add some and if you do over fill take a long hose and vacuum pump and pump some out....take your time Patience is key here :ugh2:
1 - 7 of 7 Posts
