Ok i need some serious help. I noticed some vibrating from under the car and upon inspection i found one of the bolts was missing from the transmission crossmember. Normally this wouldn't be a problem but for some reason on my car, the nuts that are supposed to be welded into the frame are loose, which makes it very difficult to get the bolts in in the first place. Anyway, when then bolt came out, the nut moved away from the hole and i can't get to it. I tried taking out the passenger seat so see if i could get to them from under the carpet but no such luck. Any ideas on what i should do? I don't really feal saft about leaving one of the bolts out of one side of the xmember.
