I am going to install a transmission temperature guage today. Does anyone know of an easy spot to place the probe in? What is a good temp range? Thanks.
I bought a kit from Summit that has a tranny filter, and temp gauge already tapped into the filter assembly. That way, the filter will catch debris if I start to thrash my tranny (with my single turbo). I think the cost was around $65.
Hello everyone I got a PHR dual fan harness and I would like to know how can I hook it up on my Aem v2 and which pinout it's going to be I need you guy help
My 94TT is BPU+ and I just got a Haltech Elite 2500 to go standalone. Sticking with stock fuel (upgraded injectors though) for now, and would like to drop in a fuel-pressure sensor somewhere. Is there any easy spot to do that ? Maybe the banjo/union bolt on the existing fuel-pressure...
After I have installed all the new seals, BCsprings, retainers, locks and buckets,
with T-belt off, put crank at -10 btdc so all pistons are slightly down, install new BC 272 cams, install cam gears, torque cams as per manual. Then turn CAMS clockwise to tdc notches, and than turn CRANK to tdc...
