the driveshaft isn't even hooked up to the car, and it won't go into gear, with car on or off or clutch in or out , so i loosened Pressure Plate and pulled it back clutch disc is in right and still won't go into gear at all, you think a shifting fork could be in a bind, or just hung up some how? I am going to drop it again huhhhhhhhh...... then shake it spins input shaft beat it around see if i can free it up, then if not back in with old tranny and hopefully company will give me a refund or switch off trannys for another.
