Hey Curt,
I tried my best to search without the search feature for the part# and prices for the things I need. I found most of the parts but couldn't find a few.
First, I'd like to see if all these prices are up to date and correct for a 1997 Toyota Supra. Also, please list parts that I might need for the problem I've listed.
Coil Pack Clips
problem: pins are fine but the clips that hold to coil pack are busted on the wire harness
90980-11246 connector list 5.89 cost 4.43 ea x 6
Driverside Valvecover, gasket set, & other parts
problem: Driver side valve cover snapped and both valve covers leaking
11201-46040 Cover Intake List 222.01 Cost 166.84
11213-46020 Rh V/c Gasket List 13.67 Cost 10.28
11214-46011 Lh V/c Gasket List 13.67 Cost 10.28
90210-07001 V/c Bolt Washers List 2.03 Cost 1.53 Ea X 16
12262-46020 Rh Pvc Hose List 9.12 Cost 6.85
12263-46010 Ctr Pvc Hose List 8.32 Cost 6.25
12264-46010 Ctr Pvc Hose List 8.32 Cost 6.25
12204-46020 Valve Pcv List 4.98 Cost 3.75
12261-46031 Lh Pcv Hose List 7.14 Cost 5.36
90480-18001 Pvc Grommet List 4.23 Cost 3.18
90105-06166 Bolt, V/c List 0.63 Cost 0.48 Ea X 12
Targa Weather Stripping
problem: Targa leaks both sides
63251-14050 Weatherstrip Targa Frt List 55.96 Cost 41.39
63252-14020 Weatherstrip Targa Rear List 55.96 Cost 41.39
62383-14030 WEATHERSTRIP RH LIST 48.07 COST 35.55
62384-14030 WEATHERSTRIP LH LIST 48.07 COST 35.55
Ash Tray
problem: broken hinge
74102-14140 ASH TRAY LIST 60.02 COST 43.66
Second, I couldn't find these parts to easily and need their part# & prices:
1994 Auto Tranny Filter & gasket
problem: tranny was swapped, regular maintenance: dropping pan, flush n' fill, already have fluid
Rear hatch bump stops
problem: hatch rattling... really annoying
TRD motormounts
problem: tranny shifts hard from P to D,1,2,R
Please provide a total with shipping to 08093. I'll send you my shipping and financial info via email.
THANKS SO MUCH
Mike
Coil Pack Clips
Ash Tray
TRD motormounts
THANKS SO MUCH
Mike
