Im looking for a built trans but i heard just rebuilding the factory one is good for like 9s and there is no need for a TH400. So im trying to find a built factory trans. Also what size turbo is the best and what fuel system is the best to match that. Im looking for somewhere in the high 700 to 800 rwhp.
OG SF Member #603
AFAIK there aren't too many stock tranny MKIV's in the 9's....there's some, but not a lot. Good tranny choices are SP, BL and Transwerks.
You should be able to hit you HP goals w/ a 67 or 71.
You'll need a full fuel system and at least 850cc inj.
Good luck
now what is the diff with the bl trans and then the bl trans with a single plate converter what is the single plate and which is better for my goals
Try searching the SF database. This has been covered many times and you should be able to find a lot of good info.
