I just bought some manual trans oil from toyota and I was wondering if anybody has done a w58 fluid change ? I need instructions on it and have searched for it but come up with nothing in either mkiv.com or here... plz help
if you have a pump.. then it's easy. or if you got 3-5 feet of 3/8 or 5/8 hose from kragen. I believe it's a 23mm socket. You'll need an 23mm open end for the feed plug. I just use a vice grip, cause mine was strip. just open the drain plug, on botton of trany. and open feed plug or overfill plug. let oil drain. then close drain plug. use hose to go into feed plug. poor oil down hose and when finish. close up feed plug. I believe it's like 2.6 liters of oil. I just put in like 3. it didn't overfill. Some people say to fill unitl it floods out of overfill plug, but I went by amount in owner manual. that's how I did mine.
