1 - 9 of 9 Posts
hey guys i was just wondering if u can use the NA 5speed transmission on the 2jzgte engine??? will it fit or i have to custom all kind of things..? bcuz i just got a 2jzgte engine from venus-auto but no tranny n i want to do the swap on my supra soon... please help
feeding your habit
bolts right up, no issues. be careful when pushing the tranny with high power.
Yep, bolt right on...remember though, you'll need the 5 speed flywheel and clutch too...the supra six speed flywheel and clutch won't work...
Dave
Exiled Supra Owner
You also want to know what kind of rear end you are using. NA or TT - there are several rear-ends that will affect what differential you need in conjunction with the driveshaft.
could i use the clutch n flywheel on my NA motor...??? n running with the stock NA drivshaft n NA differential??? please let me know so i wont make a mistake guys...thanks everyone for the help..
aKa Blk96SupraTT
Time to upgrade everything at this point. You CAN run all your NA stuff, BUT i would recommend its time to upgrade atleast your clutch and flywheel right off the bat. As for the differential, an upgrade to a TT in the future would be nice. But i've heard guys still running their NA diff.
Check Your Face!!!
since were on the topic of a clutch, what all do you guys run for clutch and flywheel on your w58's? does anybody use exedy race disc or non-carbon twin disc? they come with lightened flywheels as a part of the clutch kit, so i was just curious if anybody ever used them with any kind of successful results.
1 - 9 of 9 Posts
