1 - 2 of 2 Posts
mc booster
i was at the drag strip and i did my first run 14.3 seconds bad lauch. so i go up a second time and do a first and second gear burn out before i finally hook up. so before my third run sombody spilled oil on the track and it was going to take awile so i turned my engine off. when i turned my engine back on and went to put it in gear it wouldnt go in. it kind of feels like the clutch isnt fully disengaging because it engages earlier than it used to and i also have to push the pedal all the way to the floor and it still doesnt want to go in gear at idle when the car is stoped, but when the car is moving it will go in gear but its hard. i check the hydraulic system and all was fine no air in the system because pedal feel is still firm. the plunger is working also. could it be the pilot bearing or the throw out bearing. if it makes a difference i have an exedy twin disc clutch. need help please.
thanks
1 - 2 of 2 Posts
